Auto audio mute
Posted: Thu May 08, 2025 12:13 pm
by g4saq
Using Console 3.3. When using QO-100, I would find it very helpul if the Rx audio could be muted automatically when the Tx button is pressed. This would make for a much quicker change-over. Perhaps you could incorporate a tick box 'Auto mute' on the Tx DSP panel?
Brilliant work on console & TV!!!
Russ, G4SAQ
Re: Auto audio mute
Posted: Fri May 09, 2025 10:41 pm
g4saq wrote: Thu May 08, 2025 12:13 pm Using Console 3.3. When using QO-100, I would find it very helpul if the Rx audio could be muted automatically when the Tx button is pressed. This would make for a much quicker change-over. Perhaps you could incorporate a tick box 'Auto mute' on the Tx DSP panel?
You don't say which radio you are using? Also strongly recommend you update to the latest version of SDRC 3.4 as linked at the bottom of Simon's DATV blog page:
https://www.sdr-radio.com/sdr-television-beta-2
Indeed, it's essential you do this if you want to use SDR-TV. Note this is not the same Beta version as on the SDR-Radio website standard Download page.
If you are running Pluto (and maybe if not..... it's in the TX DSP options menu for some other radios including my HL2) have a look at the full duplex/half-duplex mode and some notes regarding mute facility at the bottom of this page regarding "Mute receiver when in transmit" setting:
https://www.sdr-radio.com/Pluto-transmit
Maybe you are in "full duplex" but you don't have the mute option selected?
