Quick Access Toolbar
Posted: Sat Sep 26, 2020 3:18 pm
by stevejerome
Is it possible to have the ‘mode’ - USB, LSB etc. on the quick access toolbar ? I can’t find the ‘buttons/s to add if it is !
Thanks !
Steve Jerome
Re: Quick Access Toolbar
Posted: Sat Sep 26, 2020 9:35 pm
Hi Steve
At the moment it is only possible (AFAIK) to add commands from the Ribbon Bar into the Quick Access toolbar. So the nearest you can get is to add a button in QAT to enable/disable the DSP panel and then select the mode from there in the normal way, then click again to hide the DSP panel.
Sorry to ask, but why change mode in the QAT when it is available in the DSP panel? I guess you want to operate with DSP Panel normally closed for some reason?
One request I made to Simon a long time ago (by the way your post is in a slightly odd place - you posted in "Forums" which is more for questions about the actual Forum software itself - yours would be better in the "Requests" section) was for it to be possible to add keyboard shortcuts to any button or control in the GUI. So for example I would like to be able to allocate "U" to USB, "L" to LSB, A to AM etc.
I think it is maybe on Simon's "to do" list but quite likely a long way down!
Posted: Sun Sep 27, 2020 5:51 am
I could add an optional entry in the ribbon bar with modes, filters, preset audio filters but don't know if that's a good idea.
Posted: Sun Sep 27, 2020 10:30 am
by stevejerome
Thanks for this Max ; I used the ‘Forums’ section because I was more asking a question not a ‘request’. I assumed the feature I was asking for was there, but I couldn’t see it !
But as it’s not, it is a ‘request’ now ! I don’t the DSP panel much (and so don’t have it visible), other than to change mode, so to do this with 1 click rather than 2 would be great. As you say, shortcut keys would also be a good solution.
Steve
