Ettus / UHD options
Posted: Sat May 10, 2025 6:51 pm
Is there a way to configure the analog bandwidth setting and the sample rate setting for UHD devices independently? I'm using a B210 and the "Bandwidth" menu options cover a certain range of possibilities but not everything you might want. For example, you might want to set the front end filters to 10MHz but (over) sample at 40MHz. I'm assuming the analog filter BW is set to match the sample rate, or vice-versa, since the selected bandwidth also becomes the sample rate? I looked at the radio definition screens but did not find a way to set those options there. Clearly the bandwidth menu can't provide this function, but perhaps it could live in the radio-specific panel in the DSP pane, which currently houses "IQ" and "DC" correction options?
Best,
Mike
Best,
Mike
