win11 USB performance tuning?
Posted: Sat May 10, 2025 7:06 pm
Hello, running SDRC on a win11 Dell inspiron 16 plus 7620 with 32GB RAM. With a B210 USRP connected to the USB 3.1 port, I can get the 28MHz BW option to stream smoothly. CPU use is low and GPU use is maybe 30%. But, I cannot use the 56MHz BW option without sample loss; judging from the length of a recorded segment vs. the clock time it took to record it, I'm losing about 30% of the samples at 56MS. (E.G., a recording made over 30 seconds is only 20 seconds long when played back, and the audio sounds sped up.) CPU and GPU use also claim to be low while this is occurring.
I've scoured the web, updated all the drivers I can find, turned off all the power saving options I can find, but still no joy. 56MS should be just under 2Gbit/sec, and the laptop specs claim it can do 5. I don't have any other USB devices connected to that side of the laptop, and I'm not using a hub.
Anyone found any tips or tricks that helped them achieve better USB throughput?
Mike
Mike
