Using Long Distance USB
Posted: Tue May 20, 2025 3:47 pm
For various reasons my antennae are some distance from my shack so upto now I have used ICRON USB ranger 2204 which allows two boxes of electronics to be connected by network cable, the box at the antenna end has the SDRs pugged into it and the box at the shack end is hooked up to the computer by usb.
It works fine with the RTL dongles and a Hackrf but if I try and use my SdR play Dual or Play V2 the display is just a series of closely packed spikes and the audio is a hi pitched whine.
I have set up the system all in one place to make swopping plugs easier, if I plug the Play sdr's directly into the computer everything is fime but using the Icron box of tricks I get the row of spikes It does this when set to any frequency, the Icrons are powered by 5v 3amp PSU's.
I have had it working at some time but medical matters goto in the way and I had to leave it for a while, now i am at a loss to know what to do, can anyone offer assistance, is there a setting in Console that affects these usb extending devices?
