Pluto 2nd RX / TX Channels
Also known as ADALM-PLUTO.
zs6jpl
Unread post by zs6jpl »
The Pluto+, LibreSDR and Adalm-Pluto Rev C or D both come two RX and TX channels. It is really nice to connect RX1/TX1 to your QO-100 setup and RX2/TX2 to your other setup. It makes life so easy without having to fiddle with SMA connectors every time you want to play radio and swop between applications.
I have searched the web up and down looking for info on how to switch SDR Console between RX1/TX1 and RX2/TX2. All the info I could find was that it is hidden in the background somewhere in SDR Console already, I looked and could not find it. I do not want to run both pairs of ports simultaneously; I just want to select pair 1 or 2 at any given time.
Any idea on how to get SDR Console to switch between ports either at startup or when working would be highly appreciated please?
Johan ZS6JPL
Johan Lehmann
ZS6JPL (ZS0JPL, ZS1JPL)
Re: Pluto 2nd RX / TX Channels
I believe this is something on Simon's todo list.
zs6jpl wrote: Wed Jul 30, 2025 1:52 pm I have searched the web up and down looking for info on how to switch SDR Console between RX1/TX1 and RX2/TX2. All the info I could find was that it is hidden in the background somewhere in SDR Console already, I looked and could not find it. I do not want to run both pairs of ports simultaneously; I just want to select pair 1 or 2 at any given time.
Johan ZS6JPL
Have a look at the notes for Pluto implementation here, specifically the "Antennas" heading:
https://www.sdr-radio.com/implementation
As Joanne says, I believe this is not currently possible but to be added hopefully.
