DX Cluster
Posted: Mon Sep 28, 2020 10:45 pm
by G3TKF
First Posting to new Forum - so apolgise if I get it wrong!
Trying to get DX Cluster to display spots and wanted to set filters at local Cluster GB7BAA ... (Don't need to see a spot by a JA3 of his local on 10m !) I can't see anyway to type commands into the Cluster from SDRConsole - have I missed it or is it still under development ? Any updates on Dx Cluster since 3.0.24 ?
Robin
G3TKF
Re: DX Cluster
Posted: Tue Sep 29, 2020 4:26 am
Hi Robin,
In the DX Cluster window click the ellipses button. In the Properties edit the Preamble, this is where you define any configuration. I've never applied filters myself but anything you can do is available here.
Re: DX Cluster
Posted: Tue Sep 29, 2020 6:19 am
by G0OFE
Can't remember what software BAA is using - here I use GB7DXS, set my filters once and thats it.
What I also do here is use VE7CC cluster interface software (which acts like a cluster node on your own machine) - use that to connect to your cluster of choice, then any instance of SDRC, logging software etc connect to the instance of VE7CC.
Depending on the software your cluster is using, VE7CC can do the filtering for you.. you tell VE7CC, VE7CC tells the cluster.
Worth checking out.
Re: DX Cluster
Posted: Tue Sep 29, 2020 7:01 am
G0OFE wrote: Tue Sep 29, 2020 6:19 am
Worth checking out.
Ah - I have been thinking about writing a DX Cluster node with Visual Studio C++ to get away from Perl and have flexibility for the future.
