Inputs not saving correctly
Posted: Sat Apr 18, 2026 4:33 pm
by FiregroundAudio
Apologies if this has been reported before. The short of it is I'm monitoring 3 conventional channels at the same time, one SDR, 3 receivers inputting to 3 virtual audio cables. Trying to save this configuration into my favorites list. I've ensured the correct virtual audio cables are selected in the Audio column & checkmarks in the Add column ticked as you'll see in the attachment. When going to retrieved the saved favorite it'll revert all 3 inputs back to the presently selected receiver's input and I have to change them back every time. This is an issue on beta v3.4, I reverted back to the stable release v3.3 and it's an issue there as well. Please fix!
Thanks & 73
Re: Inputs not saving correctly
Posted: Sat Apr 18, 2026 4:42 pm
by G0OFE
One thing to check - In the Favourites Menu, under "Manage" is an "Options" button with a speaker symbol. If "Keep current device selection (speakers, headphones)" option is ticked, untick it.
Posted: Sat Apr 18, 2026 11:26 pm
G0OFE wrote: Sat Apr 18, 2026 4:42 pm
Seconded. Just to be sure it was still working OK I just tested this and Favourites recalls the audio selection with a different VAC for each RX with that option unticked so it is still working exactly as intended. I'm on latest v3.4.
Posted: Sun Apr 19, 2026 5:46 am
I would also suggest that the audio destinations exist at the time SDRC is started. Do not start SDRC and then the audio cables.
