TX Audio Bandwidth
Posted: Mon Aug 10, 2020 6:45 pm
Had a report that ESSB is not working, specifically audio bandwidth is restricted to 4 kHz.
This may be a DUO setting, will check. Other radios such as Pluto are working OK with bandwidths > 4 kHz.
Re: TX Audio Bandwidth
Posted: Sun Aug 30, 2020 9:06 pm
by Mag loop Simon
Is this a bad thing???
( lol sorry..but..)
No its 4khz max on mine..but not being a fm radio dj do not care!!
Posted: Mon Aug 31, 2020 6:07 am
by G0OFE
Ok
Lets try again..this is 3rd time ..giving up after this..
I have just released your posts now I'm awake
New users have their first few posts held, this is an anti-spam measure. Once a small number of posts have been approved, you will no longer have posts held for review. That process is automatic.
Posted: Mon Aug 31, 2020 11:18 am
by Mag loop Simon
Ah..i see
Please then delete all apart from first one..thank you!!
Opps
Posted: Mon Aug 31, 2020 12:06 pm
by G0OFE
Done! Though you should be able to delete your own posts.
Posted: Tue Sep 15, 2020 6:06 am
by NN4F
Simon G4ELI wrote: Mon Aug 10, 2020 6:45 pm
The radio can do 6kHz, but its a firmware setting, mainly aimed at AM but it is possible, although Franco likes to stay within the legal limits of the licensing authorities. I'll see what we can do
Paul
Posted: Tue Sep 15, 2020 7:21 am
NN4F wrote: Tue Sep 15, 2020 6:06 am
Paul
There will be some wideband modes people may wish to use. 6 kHz is fine for SSB/AM but what about narrow FM - I'm using a Q5 Signal transverter with the DUO and in theory may wish to have FM QSOs. Going up to higher bands via transverters and the options increased.
Posted: Thu Sep 24, 2020 11:17 am
by W2PHL
Paul
Thanks for looking into this Simon and Paul.
It certainly would be nice if the Duo's internal menu had wider settings as well. I had the pleasure of meeting Franco at the ARRL 100th Anniversary show (2014). We discussed this topic and I thought an update would soon be in the works. I subsequently made a request or two on the message board but have since given up. Hopefully this gets done!
73, Phil /w2phl
