Software
Posted: Tue Aug 11, 2020 4:06 am
These forums use phpBB which is quite probably the most commonly used forum software software available today. It benefits from a professional approach to development and is very easy to install. On a new Windows installation you can be up and running in less than 30 minutes if you can follow instructions.
Hardware Intel i5-7250U NUC
Operating System Windows 10
Web Server Apache (XAMPP)
Internet Residential 60 Mbps down, 20 Msps up
The NUC runs IIS and Apache which can co-exist. IIS was already installed when the decision was made to run phpBB, as a result the Apache installation uses:
Other
Compression is enabled, as this is primarily a text-based board the network bandwidth is greatly reduced.
The NUC also runs the V3 On-Air service and my own remote server.
- Port 8080 for web services (default is 80)
- Port 4499 for for secure web browser communication. The default is 443, IIS and Apache cannot both use port 443.
Other
