SDR Console v3.0.25 Signal Meter Show/Hide not working
Posted: Fri Oct 16, 2020 6:54 pm
by Rod46
I've tried the console reset to no avail.
S Meter continues to be displayed when Show deselected.
Rod
Re: SDR Console v3.0.25 Signal Meter Show/Hide not working
Posted: Sat Oct 17, 2020 4:07 am
Screenshot?
Posted: Sat Oct 17, 2020 8:45 am
Hi Rod
Are you sure you are looking at a Receiver Pane and not the master SDRC window? The "Off" function only applies to S-Meters displayed in RX panes, not the main window. RX Pane is turned on/off in the "Receive" tab of the Ribbon Bar at top left. No option to turn off S-Meter in the main window as far as I am aware?
S-Meter on/off also applies to receivers in the RX Matrix display.
Best
Posted: Mon Oct 19, 2020 2:16 am
by Rod46
Thanks Max
That's it. I assumed this feature applied to the Main Receiver. I rarely use the Receiver Pane.
Rod
Posted: Mon Oct 19, 2020 10:12 am
NP Rod. It's probably more an issue with use of the Receiver Matrix window. Might have maybe 12 or more receivers being displayed in that and then the RX windows are small and space saving is more of an issue. Also multiple receivers in the main window. If you only use the main window (like I do 90% of the time) then most people would want the S Meter displayed there anyway.
