Bug or Feature?
Posted: Sun Oct 18, 2020 5:48 pm
I discovered I can control traveling the frequencies on a band by using the arrow keys (thanks Max). What I also discovered is if I click on the noise reduction and change it, then click back into the waterfall or spectrum or the frequency list between the two, when I use the arrow keys to move to different frequency, not only does the frequency change but it cycles through the noise reduction settings at the same time. I have to bring up the direct entry frequency window (double press ctrl key or long press it), dismiss it then the arrow keys will once again move only the frequency indicator.
Bug or feature?
John
Bug or feature?
John
