Enabling CUDA causes SDRC to lockup when starting radio
Posted: Thu Oct 22, 2020 11:39 pm
by NO6B
Based on Simon's recommendation I bought an NVIDIA GTX1650 to replace the Intel integrated graphics in my i7-4770 CPU. However, after starting SDRC for the first time after installing the card, it locked up when trying to start a radio (doesn't matter which one). So I started SDRC without starting a radio, went into the options & found that CUDA had enabled itself. So I tried turning it off, & now SDRC works fine. But if I turn on CUDA, close SDRC, restart it & try to start a radio it locks up again.
Fortunately I'm getting much better performance even without CUDA (can now run the RX-888 at full 32 MHz), but it'd be nice to be able to use it in SDRC.
Bob NO6B
Re: Enabling CUDA causes SDRC to lockup when starting radio
Posted: Fri Oct 23, 2020 2:27 am
by NO6B
Well of course I had to post the above in order for the problem to resolve itself
Actually I did reboot the system due to renumbering my COM ports. Perhaps something else fixed itself during that reboot.
BTW I notice no real difference in CPU load between CUDA & IPP when the FFT resolution is set to /8. When set to default or higher it does help in that the CPU load is the same as when set to /8 with or w/o CUDA. But like I mentioned in my previous post the GTX1650 is taking a big load off of the CPU even w/o CUDA enabled.
Posted: Fri Oct 23, 2020 4:44 am
NO6B wrote: Fri Oct 23, 2020 2:27 am
And it's helping with the graphics.
