HRD does not respond after adding a second receiver to SDR Console
Posted: Sat Nov 07, 2020 9:03 pm
by User3106
A problem I have recently come across (after moving from a Windows 7 to a new Windows 10 PC) is that HRD (which I use for logging only) does not respond after adding a second receiver to SDR Console. Things work perfectly fine if I continuously move a single receiver around to different frequencies. The connection to my rig (SDR Console to rig using Omnirig) shows a very crisp and fast response. HRD also follows the frequency well, though a bit more sluggishly.
As soon as I add a second receiver in the SDR Console, HRD stops responding. The Omnirig connection remains quick.
I am using the latest versions of SDR Console, HRD, vspMgr and Windows 10. Would very much like this functionality, or perhaps suggestions for a new logbook to replace HRD in this instance.
Welcoming all suggestions and advice!
Re: HRD does not respond after adding a second receiver to SDR Console
Posted: Sat Nov 07, 2020 9:16 pm
by m3ghe
I run a similar setup and don't have that issue.
Maybe a VSP issue?
Posted: Sat Nov 07, 2020 10:03 pm
by User3106
What do you use for your VSP?
Posted: Mon Nov 09, 2020 12:21 am
by User3106
Well I just noticed that HRD dopes NOT lockup. When you add a second or more receivers in the in the receive pane, this becomes a sub-frequency in HRD. The initial receiver remains the main frequency and each additional receiver as selected becomes the sub-frequency in HRD. You can choose to have the sub-frequency saved into the log database but I don't know how the actual frequency used in SDR Console can be identified. There is no way I know of to swap main and sub in HRD.
So at least there is no communication problem with virtual serial ports, but frequency ID becomes at bit more complicated.
Posted: Tue Nov 10, 2020 11:32 pm
by User3106
The solution to this problem which works fine for my needs is to not use HRD at all. Since all I was using it for was for logging, I found the Log4OM works great.
