SDR Console_VB-Audio Cable
Posted: Tue Nov 10, 2020 11:42 am
Until about 2 weeks ago I had been using the HF+ Discovery, SDRConsole driving 3 receivers on 518, 490 and 486 through VB-Audio Cables into 3 instances of YaND. All worked very well and my only bother was qrm on 490. And then it all went bad…….
Even strong signals were decoding as gibberish with the occasional clear text for 1 or 2 words. I assumed it was just additional noise on 518 until I noticed that quite often the ZCZC identifier would come through clear together with the 2nd line and then it would turn to rubbish. Sometimes the overnight session would start off just fine and then return to gibberish late at night or in the early morning.
Just occasionally it flips back to good decodes for a while. I can’t isolate what the trigger might be.
After many days of uninstalling and re-installing VB-Cables and SDRC and running parallel comparisons I have eliminated the following
- QRM
- YaND
- The radios. Both the Perseus and Discovery are producing full decodes all night using their native software (Perseus v5 and SDR#)
- VB-Cable. All 5 cables are working perfectly with the 2 radios and their native software
So it must be SDR Console ….. or a Windows/SDRC issue
I had resisted the Windows 10 update to v2004 for a few months but the inevitable happened and I was told that I needed to re-boot. I had just updated SDRC to 3.0.25 on the same day. And when I re-booted, Windows had messed up the VB-Cables which I then had to fully uninstall and re-install. And then the issues outlined above started…..
Is anyone else using the same combination of Windows 10 v2004, SDRC v3.0.25 and VB-Audio Cable?
Should I try going back to SDRC v3.0.24?
Any reasonable suggestions gratefully accepted…….
Noel.
- QRM
- YaND
Noel.
