Monitoring audio RX TX SDR console TX pane
Also known as ADALM-PLUTO.
Jacques
Unread post by Jacques »
Hello all,
Pluto SDR Console V3.025 for QO-100. Audio is noisy and has a lot of distortion when monitoring audio (Monitor , RX in the Transmit pane) . It used to work fine .
Windows 10, I7 PC
Any ideas ?
73 jacques F6BKI
Re: Monitoring audio RX TX SDR console TX pane
Screenshot?
Jacques
Hi S
imon attached screenshot
OK,
Thanks but I see not settings!
This time please show the TX and RX DSP panels in full! I must see your selections...
Attached is a screenshot showing the panels.
Jacques
Hi Simon
Can you make a recording?
Jacques
not easy , noticed that if SDR Console is open and if I listen to my own audio (Monitor RX) the audio is distorded granular , if at the same time I open ZOOM audio become OK ??
Jacques wrote: Wed Nov 18, 2020 4:09 pm not easy , noticed that if SDR Console is open and if I listen to my own audio (Monitor RX) the audio is distorded granular , if at the same time I open ZOOM audio become OK ??
In the screenshot I don't see the status bar, normally this is at the bottom of the display.
Jacques
See new screen shot , looks like when I monitor I monitor the microphone plus something else . monitoring the TX (Monitor TX) give bad audio but the audio back from the satelitte is good .
Please make a recording as Simon asked for. If you don't know how then have a look at this picture.
Also, please, show us the circeld part in your movie.
Thanks!
