Virtual audio line stuttering and oddities with sdr console
Posted: Mon Nov 23, 2020 6:47 am
by oh2eko
So recently guessing due to a windows 10 update Virtual audio lines became useless with sdr-console not sure what is causing it.
2 example videos
https://puu.sh/GQnbf/696ec34a80.mp4 Audio from sdr-console
https://puu.sh/GQnbF/fbfdbf55a1.mp4 Audio from sdr#
quick specs
Been trying different buffer settings to no avail and priority's
Re: Virtual audio line stuttering and oddities with sdr console
Posted: Mon Nov 23, 2020 6:56 am
I'm really not interested in videos from SDR# as I use the WASAPI drivers, showing me videos from other software just gets in the way.
- Which VAC software are you using?
- Have you looked for an update to the VAC software?
- How is the normal playback?
- Console is using ~2% CPU but the task manager shows 42%, what else are you using?
You really are running a very fast display rate, makes videos hard to watch. Try 20 or 40 lines/second.
Posted: Mon Nov 23, 2020 12:13 pm
by oh2eko
i have tried both VB cable and Virtual Audio Cable (VAC) latest with VB cable it does take a while before problems occur thou
Normal playback is fine if i put to default
is my main pc so plenty of things running.
Posted: Mon Nov 23, 2020 8:06 pm
Hi, did you tried the VB-Audio
Hi-Fi Cable?
Download button is halfway this page
https://vb-audio.com/Cable/index.htm
Posted: Mon Nov 23, 2020 9:20 pm
by oh2eko
Hmm i do get some stuttering with the hi fi one to but seems to auto correct it self so at least by ear seems fine gonna see how a NOAA sat pass decodes.
Posted: Mon Nov 23, 2020 11:32 pm
by khut
After the latest Win10 updates, the stuttering occurred. I use both: VBAudio-cable and also Vitual audio cable. The following remedied:
1. Complete deinstallation of the VAC software, PC restart
2. Download the latest software versions:
https://www.download3k.com/Install-Virt ... Cable.html
- vac464full.zip
Filename: vac464.exe
License: Shareware
Date updated: 7/18/2020
https://virtual-audio-cable.de.uptodown.com/windows
- VBCABLE_A_Driver_Pack43.zip
- VBCABLE_B_Driver_Pack43.zip
3. Reinstallation and then perform sound settings.
Posted: Tue Nov 24, 2020 12:45 am
by oh2eko
Hmm would not help in my case as i had not had VB cable before and downloaded latest and HIFI one worked a bit longer then normal but same issue occured soon.
Suspecting windows did another Fudge up similar to the DPC (Deferred Procedure Call) in update 1903(i think)
Posted: Tue Nov 24, 2020 6:32 am
oh2eko wrote: Tue Nov 24, 2020 12:45 am
Don't blame Windows, blame the VAC.
Posted: Tue Nov 24, 2020 6:41 pm
by oh2eko
so turns out old driver files were still present after uninstall and update removing them manually has fixed the problem i think at least seems to be working correctly for now.
but Thank you for suggestions
and thank you Simon for the great software
