cwtype/msrp40
Posted: Sun Nov 29, 2020 2:04 pm
by N2EIK
cwtype:
It apears to add "extra" characters then ends abruptly. I just sent (to a dummy load at very low power) a series of V's 3 V's were ok, 4 v's ok, 5 v's came out VVV-didididahdit. cq cq cq de n2eik came out as "cq cq several dits and dahs"
MSRP40:
I get pops akin to keyclicks. The monitored waveform is flattopped, as though msrp40 is outputting too high of an amplitude. Reducing the levels on the pc (vac line) or console transmit input have no effect on the pops.
Audio from cwtype TO the fdm-duo is through a VAC (virtual Audio Cable) to "SDR-Console"(Simon Brown)
Signal (IQ) fed to fdm-duo via USB.
I have used the duo with Phone, no issues, WSJT-X, no issues and I used to use with Military proprietary digital encryption software for MARS operations(mars was with SW2), all through VAC's..
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 2:18 pm
Absolutely no screenshots !!!
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 2:54 pm
by N2EIK
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 3:03 pm
1) Thanks for the screenshots.
2) Please add screenshots as attachments, this way they are archived here, not on another server.
3) NEVER cut up screenshots. I want to see EVERYTHING!
The screenshot I've copied here shows a clean signal sent via the VAC, so if console is getting a clean signal in and the TX isn't good then I think it can only be the VOX. There is a bug somewhere in the VOX, if it transitions too quickly it can leave the rig in RX even though it thinks it's in TX. PITA I know, it's on my list for December.
So increase VOX and see how it goes.
ETA: do not try to switch the DUO via a serial port from another program. I have no idea why you have a COM port configured with your CW software, this adds to my confusion.
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 3:49 pm
by N2EIK
No com port selected. Disable ptt is checked.
Here is an interesting thing. Sergei emailed me back with a suggestion on cwtype. I made VAC3 with his recommendations and
I set the VAC and cwtype sampoling rate to 11025 and now the full string is transmitted.....but.... I cant use vox on sdr-console for some reason console will stop sending after a few characters (but cwtype is still sending, different from before)... Console will send all if I manualy click TX on console and bypass vox. Inconvenient but at least we are making progress.
screenshots to come. A full screenshot?.. I use three monitors. Hmmmm(scratches head)
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 3:52 pm
by N2EIK
I do not see an icon on forum to add attachment
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 3:57 pm
by N2EIK
VOX problem solved. Had to increase vox hang. So now my only issue is MRP40... I like it better that cwtype/get, so if I could work out that clipping audio issue I would use it. If it cant be worked out then I go with CWtype/get. I suspect its an issue with MSP40, no way to attenuate the audio sig going to VAC.
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 4:25 pm
Reduce the levels, good luck!
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 5:38 pm
by N2EIK
Reduce what levels? There isnt a way (that I know of) to reduce the signal coming out of mrp40... Assuming thas the issue. I can look at the VAC line while mrp40 is sending, the VAC line is at max the full cycle. No internal software settings on mrp40 that I can see.
Re: cwtype/msrp40
Posted: Sun Nov 29, 2020 6:36 pm
by N2EIK
Simon,
I think I have all the bugs worked out. Just had a short qso on 30mtr using mrp40. Flawless, good sig report. I think I like mrp40 better than cwget/type for the following reasons; (1) one unified program. (2) very good decoding.
The down side: I can not use a key/paddle with it. keyboard send and receive sort of take the fun out of cw...BUT... I have other rigs for that
