Version 3.0.36 spectrum problem
G7JUR
Unread post by G7JUR »
Just installed the new release. The problem I have is Shaded will not stay enabled in the spectrum, after restart.
The odd thing is that when running on my laptop as a remote setup, this problem does not happen.
Philip G7JUR
BarneyBear65
Re: Version 3.0.36 spectrum problem
Unread post by BarneyBear65 »
I have the same problem with the spectrum shading is disabled after restart.
G7JUR
Re: Version 3.0.26 spectrum problem
That's good. I did a clean install, still not working correctly.
Odd thing is that it works fine on my laptop.
Both computers running Windows 10 64 Bit
My desktop has a AMD processor, and the laptop has an Intel.
Philip G7JUR
yo3ihg
Unread post by yo3ihg »
I can confirm this issue as well. It's happening on two laptops that I am using.
Vlad YO3IHG
G3TDJ
Unread post by G3TDJ »
Perhaps your CPU is classed as "low power" by SDRC. See the 3.0.26 Release Notes
viewtopic.php?t=604
...Changed definition of a low power CPU to include a CPU such as the Q8400 / Q9000 which does not have the SSE4.2 extended instructions.
If you have a low power CPU (see start of logfile) then on startup:
Spectrum shading is disabled,
A peek at the start of the log file will confirm
I'll add an option to override the automatic Low Power computer setting.
rainstar
Unread post by rainstar »
sometimes sdrradio will crash under a specific condition:
select a memory. drag the interface to another signal using the waterfall that is possibly outside of the tunable range so that the previously tuned channel is no longer being decoded, even if it is
still selected. select "back".
Hi Rainstar, if your issue has nothing to do with the start of this thread dan please start a new post and give us some more details about your computer, radio, used freq's when this happens and screenshot(s) to clarify the issue. "Stealing" an existing thread in every forum, is a recipe to being ignored. ;)
G7JUR
Still having the same problem with version 3.0.37
Philip G7JUR
G7JUR
Has this been added in version 3.0.37
Philip G7JUR
