Binaural without carrier lock
Posted: Mon Dec 21, 2020 11:46 am
Mentioned before, but thought this ought to be a new request.
The carrier-locked mode gives excellent results bringing a channel-dominant station into focus. At the same time, a co-channel weaker station tends to be masked. Experiments without carrier lock suggest that a continuously-tuned mode can help separate stations with small carrier offsets.
This is not a "magic wand":
The best I ever managed was a 2-channel "scope" showing tuned frequency waveform, and received carrier after an extremely narrow filter, speed and direction of phase shift being the tuning cue. It was rubbish, not least because I can'r design filters!
- It does not somehow "magnify" a weaker station
- It cannot somehow separate two stations with the same offset
- Without a lock, you will still get slow fading/wandering
- Steps at least as fine as 1 Hz are needed (I found 0.1 Hz much better)
- A maximum offset range of about +/- 50 Hz covers most MW offsets
- Some kind of tuning indicator would be an enormous help
