Frequency Database functionality
Posted: Thu Aug 20, 2020 4:21 pm
Provide the same type of functionality found in EiBiView
http://www.eibispace.de/dx/EIBIview30.zip
Show leading zeroes in On/Off times
Filtration by selection e.g. can choose English only
Search made case sensitive e.g currently AIR finds Cairo and similar
Search examples;
Display all on-air broadcasts in [language] e.g.English
Display all on-air broadcasts in [language] e.g.English starting in next n minutes
Display all on air broadcasts by [station id]
Display all on air broadcasts by [station id] starting in next n minutes
Display all on air broadcasts by [station id] and [language] and ...
I'm sure others can provide more examples
Search within column, column range
Select all by row value within column
Sort/Reverse Sort by row value within column
Multi-column Sort by row value within column
Select by current time (What's on now)
Select by current time plus n (What's coming up in the next n minutes)
Manual displayed results update
Auto-update every n minutes
Others will probably have additional requirements
Search examples;
