Server Error When Starting External Radio
Posted: Tue Feb 09, 2021 2:37 pm
by Hasan_N0AN
This is from KB7IJ who is trying to run SDRC with WSJTX on an Icom 7300.
Please help if you can, we are at wits end. Bottom line:
The combinations works with a Kenwood TS-2000, but it throws the SDRC error when used with an Icom 7300
Thanks much for any help, 73, N0AN
Start:
IC7300 with RX/TX breakout connectors on rear panel. On that panel I have a T on the ANT OUT with one leg going to a “ USB dongle”, currently a Funcube Pro + , and other leg going back to ANT IN on 7300.
Software players are:
SDR Console V3
Omni Rig 1.19
WSJT-X 2.4.0 RC1
Icom USB drivers 1.3 ( silicon Labs CP210x dated 20 JUN 2019 )
Hardware is Funcube Pro+ and an Icom 7300 ( firmware 1.3 ).
PC is a AMD Ryzen 9 3900 12 core with 32gb ram
OK. clean desktop, power up 7300. Then WSJTX with these settings.
settings_7300
Everything works perfectly. Audio is from the USB audio CODEC in the Icom WIN drivers over the USB connection from Rig to PC.
Now. Lets open SDR CONSOLE V3. ( remember WSJTX is still running )
then select Funcube abd START....
Next go to External Radio and press START...
settings_7300_01
totally locked up and only way out is via Device Manager and END TASK.
OK, lets do that now and restart without WSJTX running and go back into SDRC ...
SDRC start.. select Funcube..Start..Ext Radio ..start, select Rig 1, REFRESH, and lastly hit TRACK...
settings_7300_02
RX,ing on Funcube, with full CAT to 7300. Again.. this is WITHOUT WSJTX running.
Now, with a smoothly running SDRC/7300 combo.. if I were to start WSJTX, ( with the settings noted above) it would immediately throw a RIG CONTROL ERROR and refuse to work.
In synopsis.. I can run WSJTX __OR__ SDRC but not both Using OmniRig and trying for full CAT between all devices.
I CAN use SDRC, WSJTX and a Kwd TS2000 all at once and have full CAT/PTT between all players.
So, tour complete. Cookies and lemonade in the back of the room. Thanks for coming by.
Cheers
Rich Blaney
KB7IJ
Re: Server Error When Starting External Radio
Posted: Tue Feb 09, 2021 2:48 pm
by Hasan_N0AN
Here is a pix of the settings being used an an error:
