Analyser: Resolution: Lines per second
Posted: Tue Aug 25, 2020 12:52 pm
Hi, Simon - in the Analyser, the number of lines vs. time seems to be limited:
* max. 20'000 [under: Analyser -> Definition -> General Settings -> Update Rate]
This limits the max. time resolution of one millisecond to 20 seconds.
If you have longer pieces, the resolotuin is automatically reduced to a matching value - but not with equal distance from step to step, if you don't exactly calculate the relationsship of time vs. resolution.
I would like to suggest a (much) more wider range, if pssoble. Plus an evenly distance from step to step to do some FFT.
2 x 2 rulers (calculating) in the "Signal History" window would, furthermore, often make 3rd party CSV software unnecessary.
Thanks and 73: Nils, DK8OK
