Do you have any plans to offer LAN support for the IC-R8600? To me it's just a much cleaner interface with minimal interference. I know you can do it with the Afedri LAN-IQ, just curious.
Thanks for your continued great software.
Scott/KC1UA
LAN Support
Re: LAN Support
Not sure there is a LAN interface I can use as I think there are some CI-V commands (will have to check). You're the first who has asked for this.
Re: LAN Support
It's USB only, look at this guide.Simon G4ELI wrote: ↑Thu Aug 19, 2021 2:59 pm Hi,
Re: LAN Support
Guide link doesn't work here:
Forbidden
You don't have permission to access this resource.
Forbidden
Re: LAN Support
If you can get here you can follow your nose to the file Simon pointed towards. Just accept the terms and go.
Re: LAN Support
Hi Simon, I’m the second one asking for this feature.Simon G4ELI wrote: ↑Thu Aug 19, 2021 2:59 pm Hi,
Recently has been released some softwares connecting to (and managing) IC-R8600 via lan interface.
Would be amazing if also Sdr Console could do this.
Thanks, Tony.
Re: LAN Support
The IQ interface is via USB only as far as I know. I'll check though. For a remote radio there's always the server.mactonio wrote: ↑Thu May 19, 2022 8:12 pmHi Simon, I’m the second one asking for this feature.Simon G4ELI wrote: ↑Thu Aug 19, 2021 2:59 pm Hi,
Thanks, Tony.
Re: LAN Support
So,
Checked, read this PDF: https://www.icomjapan.com/support/manual/1769/
As you see, IQ data is only available via the USB connector. This other software is not IQ based.
