More to read about this subject at https://www.sdr-radio.com/server
So you are using the RSP directly otherwise you would have known
As Simon already pointed out, SDRC 3.0.26 should work fine with the latest SDRplay API v3.07
It does work fine here with a RSP2pro and SDRplay V3 radio selection in SDRC.
Do you still have that message saying you need API v3.06 instead of 3.07?
- installed the new API or latest SDRuno WITHOUT the RSP connected? Connect it only after the installation has finished!
- be sure SDRC and SDRC Server process has stopped before you install the API again. Not sure if this helps but to be sure...
- try to connect the RSP via a USB hub with a external power supply. Lots of computers can't deliver the needed power.
https://www.sdr-radio.com/usb
Please let it know if this solves your issue, Leon
