Page 2 of 2
Re: external radio issues with rtl-sdr and ic756p2
Posted: Thu Jun 23, 2022 5:05 am
by Alezis
iz1fks wrote: ↑Sat May 14, 2022 9:45 am
I am having similar issues with a FT1000D on it's IF output.
Yours seems to scroll better than mine but I noticed in your video one of the issue I am also having, when you ZOOM the scope, there is a frequency shift happening and I saw it also on your video and I cannot figure out what cause this issue...
Posted: Sun Jul 24, 2022 11:28 am
by iz1fks
[/quote]
[/quote]
thanks for your reply, I think the issue is about software setting with CAT syncro as well as a software bug about zoom setting with CAT activated. I really don't understand why these bugs are not solved because the IF external radio option would be great with those problems fixed
Posted: Mon Jul 25, 2022 1:59 pm
Note that in SDRC zoom is ALWAYS around the center frequency of the display. Personally I consider that a bug. Simon does not. This is his toy. So I accept it.
Posted: Mon Aug 01, 2022 6:19 pm
by iz1fks
jdow wrote: ↑Mon Jul 25, 2022 1:59 pm
the issue is not that is around center frequency, the problem is that the zoom level reset at each frequency change
Posted: Sun Aug 07, 2022 3:16 pm
by CT2HUU
Hi
I have the same issue with the "auto zoom out"...
Did you find a solution?
Posted: Sun Dec 25, 2022 4:24 pm
by iz1fks
Hello, tried latest 3.2 version, no change on this issue. Radio->SDR setting doesn't work as it should and enabling sdr->Radio setting waterfall is okay moving in the right way while spectrum is freezed during vfo frequency changing. 73 and Merry Xmas to everybody
