External Radio: Save settings for different radios in different identities not possible
Posted: Sun Aug 23, 2020 7:57 am
Hello
I just wanted to use the SDR-Console for 80m with the Kenwood TS-480HX and for QO-100 with the FT-857.
Now, when I save the upconverter-offset (10057 MHz) for QO-100 in the FT-857 identity, then this upconverter-offest-setting is also used in the TS-480HX identity. So I have to deactivate the upconverter-offset manually when I want to use the TS-480HX.
Where can I save those external radio-settings for two different radios?
Thank you
André
Thank you
André
