Good afternoon.
I have a SDR Console running with a Pluto for QO-100
I would like to access that from remote.
The software locally is running and I can RX (and TX) QO 100.
I did all the procedure to run the server manager, and I can access from remote, from another pc with SDR console. But I can't hear anything. With the same procedure I can access a SDR RTL key, so the connection seems to work. It seems that the driver for the Pluto doesn't work. I also noiticed that the Pluto device disappears after version 3.0.23. I cannot find Pluto in the list of devices to connect at the server manager in version 24 or 25.
Anybody could gently help me? Thanks in advance.
Carlo
Server manager with Pluto is silent
Re: Server manager with Pluto is silent
TX'ing via any remote has not been implemented, and according to the 'Jedi Master', it may never.
Would be awesome to access my ANAN 200D via remote (outside my LAN). I can listen via the LAN, but no TX. For now I use Icom's via RS-BA software, which also allows me to turn the radio off when not in use. The ANAN has to be powered up 24/7 to work as a remote RXR.
Hi Kriss, thank you for your answer. Now I can't even RX with my Pluto. Server manager let me see the radio on the internet, but nothing is heard with Pluto driver. Maybe a driver issue? The driver itself disappears after version 23.
Hope to get help from somebody
73!
73!
Not supported.
