Suggest expanding range of Visual Gain, and hiding signal strength meter.
norbinz
Unread post by norbinz »
For the SDR Console suggestion box:
1. Please consider expanding the "Visual Gain" setting. Currently it goes from +30 dB to -40 dB in 5 dB steps. I'd like it to go down to at least -75 dB in 3 dB or finer steps. That would allow me to approximately calibrate the dBm amplitude scale of the spectrum plot when using my SDRplay RSPdx.
2. Please consider adding an option that disables/hides the signal strength meter, or move the meter outside the spectrum pane. I usually read amplitudes from the spectrum plot, not the meter. The meter obscures some of the spectrum plot.
Thank you
