Not sure if I requested this before; don't remember.
If I did, I apologize,
Not important, but perhaps something to consider.
I'm always playing around with the RF Gain Settings.
It would, I think, be a lot easier if it was implemented as a Slider. Perhaps an option for either way ?
And in the Memories, the 1 to 9, with the 20 allowable designations:
In addition to selecting which of the 1 to 9 you want to see, might it be possible
to give a name to each of the 9 ?
e.g., Aero. in addition to number 1 (or both perhaps)
Maritime for No. 2
etc.
Bob
RF Gain To A Slider ?
Re: RF Gain To A Slider ?
Hi Bob,
To name the Memories, click on the down triangle and select Edit. You should be good from there. (see attached).
Barry
WB2ZXJ
Barry
WB2ZXJ
"I'm always playing around with the RF Gain Settings." Generally speaking this is not a wise way to use the RF gain control, even for weak signal CW use. An exception exists when you have strong enough signals your screen explodes with spurs before your SNR readings stop increasing with increased gain. In a more normal setting once your SNR stops rising the RF gain is pointless and why might you want to degrade performance by using lower than optimum gain for SNR?
For CW use you can turn off the AGC and use the MGC setting in that panel the way the RF gain is used in traditional analog radios.
Good suggestion.
Bob
Good suggestion.
Bob
Agreed, with SDRplay just let the AGC do the work.jdow wrote: ↑Thu Nov 18, 2021 12:30 pm "I'm always playing around with the RF Gain Settings." Generally speaking this is not a wise way to use the RF gain control, even for weak signal CW use. An exception exists when you have strong enough signals your screen explodes with spurs before your SNR readings stop increasing with increased gain. In a more normal setting once your SNR stops rising the RF gain is pointless and why might you want to degrade performance by using lower than optimum gain for SNR?
