I need to have a separate RDSdatabase for each identity I run. As it is set up, whether I open Main or Ident1 the default database rdsdatabase.sqlite opens up.
It is slightly more complicated than that. If I create a database - rdsdatabase_001 for Ident1, and later close down - when I re-start SDRC in Main - it uses the ...001
database.
So - I can open Main with rdsdatabase.sqlite as the default. Then open Ident1 and point it to rdsdatebase_001, the two instances will run with the separate databases. It appears that when closing down SDR Console, whichever instance is the last one closed - that is the rdsdatabase that will selected next time round by Main and ident1.
What is needed is that each ident uses its own database independently - and I know my explanation doesn't read very well.
DaveB
RDS - separate databases for each instance
Re: RDS - separate databases for each instance
Dave,
I would expect the identity to store the RDS log in its own folder.
Seems that it remembers the last database used is remembers across all identities.
I'll check this....
I'll check this....
