Hello Simon,
is it possible you could bring the bandwidth of 48k in WFM mode up to 75 or 100k ? there is a new satellite up, Bobcat-1 and is
transmitting 57k6 data. 48k is not wide enough. BFM mode will not work.
73,
Rocky
W2RTV
Possible to to go past 48k bandwidth in WFM
Re: Possible to to go past 48k bandwidth in WFM
Rocky,
Yes - but first please send me a good screenshot or better still an IQ (Data) recording, this will help a lot.
ok Simon ,i will get an I/Q recording and a screenshot to you when it goes back to 57k6.
thanks,
Rocky
thanks,
Rocky
In the past it was possible to add higher bandwiths, they still work fine here: 50/80/100/120/150 Khz but i can't copy/edit them anymore.
Rockey do you know if the D/L freq is 436.600 MHz?
What I'll do is run at 48k if the filter is 48k or less, 96k if 96k or less or 128k if > 96k.
Should be easy, I'll just wait for the screenshot / IQ so I know what I'm dealing with.
I've just tried this logic with BFM - works well with three different sample rates. I'll add to WFM and post a kit today.Simon G4ELI wrote: ↑Thu Nov 19, 2020 7:02 amWhat I'll do is run at 48k if the filter is 48k or less, 96k if 96k or less or 128k if > 96k.
Ah - isn't going to work. The audio output is always resampled to a constant 48kHz in my demodulation engine.Simon G4ELI wrote: ↑Thu Nov 19, 2020 8:06 am
So, the only solution is to add an optional extra for FM demodulation > 48kHz. Let me see the screenshot and IQ data please.
here is my dropbox link to I/Q /wav recording at 57k6
https://www.dropbox.com/s/yvfuwmy6bdj73 ... v.wav?dl=0
ok i am trying to post my dropbox link to recording. i hope it came through.
Rocky
Rocky
