Hi.
While I am sitting here setting up tonight's scheduling, it struck me that the procedure could be made a little more easy.
When setting up a schedule for the next day, the interactive window proposes the current date when checking the weekday box.
That is fine, but if you pick the next day as starting day (or any other coming day) the 'stop day' remains the present day. I.E. it shall stop before it started! I can hardly think of when one would like that.
If the 'stop day' would be set automagically as the same day as the start day (when chosen), it would ease the schedule setting.
If, you want to have a later day than the same day, as the 'stop day', you would need to manually set that. It is OK.
See attached screenshot.
73 / Ingolf, SM6FHZ
Scheduler interactive window
Re: Scheduler interactive window
Hi Simon.
Would this fix / feature somehow fit into 3.0.27 ?
Is anything unclear, let me know and I will try to explain better
73 / Ingolf, SM6FHZ
73 / Ingolf, SM6FHZ
Hi.
If fixing the "Stop Receiver when recording is finished" bug it might be possible to look at this proposal as well.
73 / Ingolf, SM6FHZ
73 / Ingolf, SM6FHZ
