MODDING PLUTO
Also known as ADALM-PLUTO.
dg9bfc_sigi
MODDING PLUTO
Unread post by dg9bfc_sigi »
just a test
can be deleted later
:D
greetz sigi
dg9bfc_sigi
Re: MODDING PLUTO
seems to work fine
Re: MODDING PLUTO
Moved to test team - can you still see it?
dg9bfc_sigi
Re: MODDING PLUTO
?? what do you mean with moved to test team ... and can you still see it??
you mean if i still can see above picture in the post?? ... yes ...
G3WDG
Re: MODDING PLUTO
Unread post by G3WDG »
Hi Sigi
I converted my Pluto to 40MHz reference input yesterday, taking care with a scope to check that the levels were correct (or at least the same as it was with the internal oscillator).
However, I was about 500Hz off frequency when receiving a test signal on 144MHz. It seems there is an offset stored in the Pluto relevant for the internal oscillator. I reset this with SDRC to 0ppm and it now works fine.
Charlie
dg9bfc_sigi
Re: MODDING PLUTO
in config file in the pluto you will find xo correction ...
xo = ......
fill in the 40 megs
xo = 40000000 ... save config and do a reboot
