PTT via Pluto GPO pins
Posted: Tue Nov 24, 2020 9:44 am
by M0TGC
Hi
With the latest AD firmware (0.32) SDRC does not control the GPO pins on TX but with the F5OEO DATV firmware it is ok.
So, two questions:
Is there any reason not to use the F5OEO firmware?
Will SDRC drive the GPO pins on TX in the future on the standard AD firmware, or have I missed a way to configure it?
Re: PTT via Pluto GPO pins
Posted: Thu Nov 26, 2020 5:55 am
M0TGC wrote: ↑Tue Nov 24, 2020 9:44 am
Hi
So, two questions:
Thanks for this update - I wasn't aware that a new firmware had broken things. Noted, I'll update the code as soon as I have time.
Please give me a link to the firmware.
Posted: Thu Nov 26, 2020 3:19 pm
by M0TGC
Posted: Thu Nov 26, 2020 7:52 pm
So,
Maybe the new firmware has broken the library?
Has anyone else reported this?
I see this firmware is ~5 months old?
Posted: Thu Nov 26, 2020 8:49 pm
by M0TGC
Are you sure it worked on 0.31?
Posted: Fri Nov 27, 2020 6:46 am
M0TGC wrote: ↑Thu Nov 26, 2020 8:49 pm
I was told it did - I think. Please put FW 0.31 on and have a look, I have no way to test this.
Posted: Fri Nov 27, 2020 5:17 pm
by M0TGC
Hi Simon
I downloaded the 0.31 firmware from:
https://github.com/analogdevicesinc/plu ... /tag/v0.31
Installed it and checked the version using putty. No PTT via GPIO on TX.
I then re-installed the DATV firmware from F5OEO and confirmed that PTT on TX was still working.
I have a relay daughter board in the Pluto simply switching an led as I am still waiting for the necessary PA's.
So PTT on TX is not working on either 0.31 or 0.32 AD firmwares!
Rgds
David
Posted: Fri Nov 27, 2020 5:29 pm
Please attach your GPIO configuration window.
Posted: Sat Nov 28, 2020 2:41 pm
by M0TGC
Simon G4ELI wrote: ↑Fri Nov 27, 2020 5:29 pm
Where do I find this?
Posted: Sat Nov 28, 2020 2:45 pm
Options in the radio panel, just above RIT and XIT.
