Alternative USB relay boards
MIDI, ...
Jomac_uk
Unread post by Jomac_uk »
Reading the manual it recommends the Dencovi USB relay controllers. Will the generic USB relays boards work just as well?
Re: Alternative USB relay boards
Hi, did you look here?
https://www.sdr-radio.com/relays
or/and pls define what generic USB relay you are reffering to.
r/Leon
Jomac_uk
Thanks for the reply. I did read somewhere a little while back that SDR Console recommended the Denkovi relay boards based on the FTDI chip. At the time I didn't have these boards but since this post I managed to track down a couple of 8 relay boards on eBay. When I posted this topic, I wondered if other USB boards using the FTDI chip were fully compatible with SDR Console in both read and write as some boards you could only write to.
