Automatic Mode change
hurz_66
Unread post by hurz_66 »
Hi, i´m using SDR Radio now for several Years an im very happy with it.
(donatet too)
But when i use the mousewheel to tune often the mode switches to another mode, i.e. usb to lsb.
Is this a bug or a feature?
I can´t find where i can switch it of.
thx
michael
Re: Automatic Mode change
To use the mouse scroll wheel to tune, the mouse has to be somewhere over the spectrum scope or on the water fall. You can also place it over any one of the frequency digits in the DSP widow if you have that displayed.
You can also revers the direction of the scroll wheel if you go to Receive on the ribbon bar, then click on View, then Options. ie Roll forward to increase frequency and roll back to decrease frequency.
I'm not sure how you are able to scroll through your Mode's with the scroll bar, not doing it on my version 3.2 build 2720 Dated September 7, 2022 at 17:39:38. Probably a little out of date, but for what I do, it's just fine.
What version do you have? Click on Help on ribbon bar, then About Version 3 in the support window of the ribbon bar.
hurz_66
Thx for Your reply.
My version is 3.2 build 2731.
Mouse insite waterfall or one receifer matrix window, mousewheel tuning changes mode from lsb to usb.
Filter changes in some cases, too.
i tested it now several times in receifer matrix.
Mouse over frequency digits changes the belonging digits just fine wothout touching Filter or mode.
