Old driver version
0xFFA500
Old driver version
Unread post by 0xFFA500 »
Hey!
I got a SDRPlay RSPDx and I installed all drivers correctly but now if I wanna add the receiver, this message appears: https://prnt.sc/153i5vf
The problem is that my installed driver is too new or the SDR Console driver is too old
What can I do to fix this problem?
Re: Old driver version
It should work with the latest API/HW Driver 3.07 packed with SDRuno 1.40.2
I can recommend only one solution, un- and re-install the API again and reboot the PC before you run SDRConsole again.
Then delete the SDRplay radio (under Select Radio pane) and add it again.
I don't know your knowledge level.... but you can't run SDRC and SDRuno on the same SDRplay receiver at the sane time.
regards, Leon
