Hi Simon et al
I have got back to SDR Console after a long break, and I am trying to use it on a small mini-PC running W10. It uses a T2250 1.73GHz CPU with 2GB of RAM.
SDR Console 3.1 build 2320. AirSpy or FunCube Dongle, both receive OK, but if I try to record audio or data, the program locks up and the only way out is with CTRL ALT DEL. I have attached a screendump, and the log file before it locked up.
Tony
SDR Console 3.1 recording bug (maybe?)
- SDR Console tmp.txt
- (26.78 KiB) Downloaded 58 times
Re: SDR Console 3.1 recording bug (maybe?)
Tony, that PC is working very hard in the screengrab:
To give you an idea here's my 10 year old i7 PC running RSP2Pro:
Think your PC must be underspecified sadly as Leon says.
Thanks for the suggestions. I have run SDR Console on all sorts of old PCs in the past. Do you think that going back to a older version in Simon's now unsupported versions would require less resources. I only wanted to record some data from an Airspy in the SDR Console format for someone else to review. The Airspy works perfectly well on the same PC with HDSDR.
Tony
Tony
