Problems after W10 and W11 updates
DF1TB
Unread post by DF1TB »
After updating my 2 pcs to W10 21H2 build 19044.1566 and W11 21H2 build 22000.527 both SDR-Console 3.1 and also 3.0.27 no longer run. I get various problem like frozen screen upon starting, sometimes audio but no spectrum, can´t select radio, etc. It is sure the windows update because I tried with the second PC before I updated W10 which was okay with both SDR-Console versions. Any help is appreciated. 73 Thomas DF1TB
DF1TB
Re: Problems after W10 and W11 updates
Hi, after 2x unistall and erasing the folder in the registry 3.1 build 2320 is running now since one night. Problem seems to be solved. 73 Thomas
There is a reason these are called preview releases. MS must have messed something up, at a guess. I am guessing the official patch Tuesday may cause problems.
KA6MOK
Unread post by KA6MOK »
Interesting, I'm having similar problems only on one Windows PC, while both have the identical Window's version and nearly the same as yours. (same except for version xxxx.1568 not .1566) Can't remember when I last tried the latest version and it didn't just work... Ah well.
Have done numerous reinstalls, removes and installs, removing and reinstalling SDRuno as well. Nope. My desktop PC got working doing that, but the laptop is still broken. It has the long delayed start... w/o the selecting a device menu appearing, as it usually does. It will either totally hang or maybe go on to playing some sound but no display... and nothing works to the point of having to kill it in Task Manager to end the program.
Am interested in exactly what you did to fix it. I haven't done any Registry tweaking yet...
sdramateur
Unread post by sdramateur »
Same problem,
only when using any RTLSDR Other SDR receivers seem working fine.
Windows 10 Home 21H1 19043.1526
Jaques ZS6JV
Console
Unread post by Jaques ZS6JV »
Hi all
Just to try cast my experience on the issue of streaming not starting in my case with an Adalm Pluto SDR.
I get the issue when using SDR Console V3.1 after uninstall and reinstall of V3.0.28 I can easily start streaming and everything works fine.
*note the SDR V3.1 install was the first install of SDR Console - so no previous settings were present.
If I can help by providing logs I'd be glad to.
Adalm Pluto with latest M2k drivers
Windows version 10.0.19044 on Surface Pro 5 i5 4GB
73 de Jaques
