Multiple Pluto's SDRC onlys uses first one in the list.
duane909
Unread post by duane909 »
I have 3 ADALM Pluto sdr's all set up using IP addresses. It does not matter which one I select, it only uses the first one in the list.
Online
Re: Multiple Pluto's SDRC onlys uses first one in the list.
duane909 wrote: Sun Oct 29, 2023 5:30 pm I have 3 ADALM Pluto sdr's all set up using IP addresses. It does not matter which one I select, it only uses the first one in the list.
I guess you already read this page and also the "customizing" page that is linked from it?
https://www.sdr-radio.com/network-access
I don't have a Pluto, but did you "add" and edit a new SDRC definition, one for each for the three IP addresses?
