Screen goes blank whilst using SDR Console V. 3.3
oe8pck
Unread post by oe8pck »
I use 2 screen on my PC and when I use SDR Console V. 3.3 the screens go blank either both or one and after a few seconds they come back on again.
When I am not using SDR console this does not happen. Has anybody had this issue too? The typed letters still show up on the screen even though it is blank.
73 de Paul OE8PCK
Re: Screen goes blank whilst using SDR Console V. 3.3
Well... might need more info as what Hardware and OS you are running
Open SDRC, in the ribbon bar on top click on "Tools", in the settings cluster of icons is "DirectX Diagnostics", click on that.
Save the info and attach to your next post.
You have to be in Full Editor Mode to be able to attach I believe.
DxDiag.txt
Super Station #1 DirectX Diagnostic File
(75.47 KiB) Downloaded 64 times
oe8pck
Hi Kriss, Sri to trouble you, but the problem seems to have just disapeared. I used the QO-100 with SDR Console for 3 hours today and nothing happened.
Many thanks for your prompt answer.
If it returns I will follow your instructions.
73 de Paul OE8PCK
