Virtual Cable problem with 3.3
Hi All, I apologise if I don't provide too much info. Equipment: Pluto. I had SDR Console 3.2 + Virtual cable working with FT8, once installed 3.3 it stopped working. The WSJT was unable to activate TX correctly. If I increased audio level coming thru virtual cable, TX got activated but it stayed transmitting forever. Downgraded to 3.2 and everything is working fine again.
Re: Virtual Cable problem with 3.3
There really should be no difference. How are you triggering TX - VOX? Maybe add a screenshot so I can see the VOX settings, gain may have to be reduced.m0ppr wrote: ↑Sun Dec 31, 2023 11:41 am Hi All, I apologise if I don't provide too much info. Equipment: Pluto. I had SDR Console 3.2 + Virtual cable working with FT8, once installed 3.3 it stopped working. The WSJT was unable to activate TX correctly. If I increased audio level coming thru virtual cable, TX got activated but it stayed transmitting forever. Downgraded to 3.2 and everything is working fine again.
