Firstly, I want to congratulate you on this magnificent software! And thank you!
I got a good connection between my old Ft450d and the SDR Console. However, whenever I try to set the radio to "USB Data" it reverts to USB and so I cannot use the digital modes.
Would there be a way to include something like Data - U or Data - L in the SDR Console modes? Or another way to fix this behavior without having to disable mode synchronization between the SDR Console and my Ft-450D? Thank you very much!
Behavior with the Yaesu Ft 450D.
Re: Behavior with the Yaesu Ft 450D.
Have you seen the Mode Mapping in the external radio Options/Settings? Press question mark top right of the External Radio window (see attached picture).Fábio - PY6FX wrote: ↑Fri Feb 02, 2024 11:00 am I got a good connection between my old Ft450d and the SDR Console. However, whenever I try to set the radio to "USB Data" it reverts to USB and so I cannot use the digital modes.
How exactly are you using SDRC? How do you want to decode data? What data mode?
- Mode-Mapping.jpg (139.43 KiB) Viewed 1219 times
