Hi together,
while receiving signals from QO-100 and I open another programm the audio gets distored for a few seconds, espsecially when the software gets startet.
I am using the SDR Console with a RSP1A SDR and a notebook with Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz and 8,00 GB RAM. The SDR Console uses up to 45% of the CPU power. From 70-80% CPU load the distortion starts.
I have got the same issue not so heavy with a PC with Intel(R) Core(TM) I7-940 CPU @ 2,93GHZ and 20,00 GB RAM.The SDR Console uses only up to 15% of the CPU power.
SDR Console Version V3.3 Build 3236
Have you got any idea what the problem could be ?
I assume that the notebook is sometimes overloaded with the power of SDR Console and starting applications which leads into the audio issue.
For your sopport thanks in advance.
Regrads
Dirk
Audio Issue / SDR Console V3.3
Re: Audio Issue / SDR Console V3.3
Dirk,
That's a lot of CPU. please attach a screenshot while receiving, I'm guessing you have a wide receive bandwidth and possibly enhanced resolution.
