SDR Console V3.3 with Log4OM2 !!!
rasp123
Unread post by rasp123 »
I am trying to interface the SDR Console V3.3 with Log4OM2.
I am not succeeding to get the VFO & mode information to the Log4OM2 application.
Log4OM2 works fine with my FT991A.
An suggestions as to how to get this fixed?
Ravi
Re: SDR Console V3.3 with Log4OM2 !!!
rasp123 wrote: Mon Apr 15, 2024 12:02 pm I am trying to interface the SDR Console V3.3 with Log4OM2.
Any suggestions as to how to get this fixed?
Log4OM works very well with SDRC. Just use virtual serial port pair to connect Log4OM to SDRC:
I strongly suggest using VSP Manager from K5FR as it always seems to work very well with SDRC. Also, if you decide to use Omnirig, do NOT use Omnirig 2.0. It's not the official version and it does not work with SDRC. Get the latest version from DX-Atlas, currently v1.2 :
https://dxatlas.com/omnirig/
When using VSP Manager to set up the virtual com ports, go to Properties of the VSP Manager .exe file and set "compatibility mode" and also "Run as Administrator" (see picture):
Good luck.
