So,
Yesterday evening I finally added optional station times to the display. Will make a kit soon...
Station Times
Re: Station Times
Re: Station Times
It appears that something is not set / working correctly as the station time for Melbourne, Australia and Rangitaiki, New Zealand appear to be off and unadjusted for their DST.Simon G4ELI wrote: ↑Fri Oct 23, 2020 7:32 am
In this case excellent date/time routines from Microsoft which support time zones.
My Windows time settings and a screenshot taken with the info from timeanddate.com below.
The Simon's World Map screen capture is also available here: https://www.dropbox.com/s/hjpfe7w7krqaz ... 3.png?dl=0
Mike
Mike
Re: Station Times
Mike,
Attach screenshots here, not via Dropbox. That's why we have these forums, keep it all in one place.
Re: Station Times
Melbourne and Auckland should be OK if you select the correct zone.
Why not attach the station window so it can be read? Alt+Print Screen or use Paint.
Re: Station Times
Just for grins, one of the stations I have set is Woofferton. When I add the station time as UTC - Coordinated Universal Time SWM shows the station time as GMT - 5. Is station time based off of PC Time?
Mike
Mike
