Yes. Still not a hint of overload anywhere. On a par with the HF+ in that respect. It's far better than the Perseus/FM+ combination - the latter is just as sensitive, but overloads relatively easily.
Would think once the downconverter addon becomes available, S3 from a price v performance / software pov should blow Winradio out of the water.
S3 is here at last !! First thoughts....
Moderator: NN4F
Re: S3 is here at last !! First thoughts....
I'm not aware of any dates for the downconverter - don't know what I could use one for other than DAB+.G0OFE wrote: ↑Mon Nov 16, 2020 11:42 am Yes. Still not a hint of overload anywhere. On a par with the HF+ in that respect. It's far better than the Perseus/FM+ combination - the latter is just as sensitive, but overloads relatively easily.
Anyone remember the Realistic DX-302? 0-30Mhz rx with digital readout. £260 in 1980, equivalent to £1,123 now.
S3 still cheaper!
S3 still cheaper!
So, you're still enamoured with the S3 .
[/quote]
[/quote]
Sorry to bump in, but how about VHF Airband and/or UHF Milair scanning and/or analysing? That scanning thing with a proper scanner of course....
Best regards,
Cornel, PA3BTS
[/quote]
Best regards,
Cornel, PA3BTS
Well, I must write a 'proper' scanner next year with full logging. I have no plans to just write a toy scanner.
Great! I know it is on your list, but also that the list is long. No problem.
Cornel, PA3BTS
Cornel, PA3BTS
Daughter approves
I'll make a DXer of her yet......
Jim,
Glad you got the recording to a normal HDD, I've never had an issue here either, yes SSD is better, but my SATA drive has worked just fine, I have one user that has had issues, but that was caused by laptop being used in a hot car and laptop performance was degraded....
Paul EladUSA
Paul EladUSA
Paul Jones - NN4F
Head of Sales & Support
Elad USA Inc.
SDRPlay Betatester
Elad USA Inc.
SDRPlay Betatester
Paul,
What bit size does the Elad software use to make recordings?
Console uses 16 bit by default, 32 bit can be selected. I know HDSDR uses 32 bit. Not yet tried 32 bit on Console with 24Mhz recording, but I think I know what the result will be......
