S3 is here at last !! First thoughts....
Moderator: NN4F
Online
Re: S3 is here at last !! First thoughts....
#11
Yes. Still not a hint of overload anywhere. On a par with the HF+ in that respect. It's far better than the Perseus/FM+ combination - the latter is just as sensitive, but overloads relatively easily.
Would think once the downconverter addon becomes available, S3 from a price v performance / software pov should blow Winradio out of the water.
#12
G0OFE wrote:
Mon Nov 16, 2020 11:42 am
I'm not aware of any dates for the downconverter - don't know what I could use one for other than DAB+.
Online
#13
Anyone remember the Realistic DX-302? 0-30Mhz rx with digital readout. £260 in 1980, equivalent to £1,123 now.
S3 still cheaper!
#14
G0OFE wrote:
Tue Nov 17, 2020 7:37 am
S3 still cheaper!
So, you're still enamoured with the S3 :) .
PA3BTS
#15
Unread post by PA3BTS »
[/quote]
[/quote]
Sorry to bump in, but how about VHF Airband and/or UHF Milair scanning and/or analysing? That scanning thing with a proper scanner of course.... ;)
Best regards,
Cornel, PA3BTS
#16
Well, I must write a 'proper' scanner next year with full logging. I have no plans to just write a toy scanner.
PA3BTS
#17
Great! I know it is on your list, but also that the list is long. No problem.
Cornel, PA3BTS
Online
#18
Daughter approves 👍
I'll make a DXer of her yet......
NN4F
#19
Unread post by NN4F »
Jim,
Glad you got the recording to a normal HDD, I've never had an issue here either, yes SSD is better, but my SATA drive has worked just fine, I have one user that has had issues, but that was caused by laptop being used in a hot car and laptop performance was degraded....
Paul EladUSA
Paul Jones - NN4F
Head of Sales & Support
Elad USA Inc.
SDRPlay Betatester
Online
#20
Paul,
What bit size does the Elad software use to make recordings?
Console uses 16 bit by default, 32 bit can be selected. I know HDSDR uses 32 bit. Not yet tried 32 bit on Console with 24Mhz recording, but I think I know what the result will be......
