Can not xmit
Moderator: NN4F
Re: Can not xmit
Mike, I can appreciate that. But I took screen captures with the snipping tool and posted it in the document. If you can show me an easy way to post the screenshots to the forum I will do that.
Re: Can not xmit
To take a screenshot, use the camera icon in the top window bar on the left within Console.
To post in here, click on "attachments" below the window you're typing your post in.
If you can't see "Attachments below, click on the Full Editor button below.
Re: Can not xmit
Here are all my settings. I have checked an when I click the Tune button in the TX Pane, the radio relay goes into TX, but no RF comes out...
Forum Software limits to 5 pictures and will add the next 4 in the next post.
Re: Can not xmit
Remaining Screen captures of my settings:
Perhaps I need more clarity on how the entire windows sound settings need to be set up???
Thanks for all your help.
--Christoph
--Christoph
Re: Can not xmit
Tnx es 73
Christoph, NE7EE
Re: Can not xmit
Start the Radio. Take a screenshot of the whole console, I'll annotate what needs doing. No other windows opened please.
Re: Can not xmit
OK,
Transmit Pane (RHS)
Transmit Pane (RHS)
- Increase the Gain, 90% is good
- Spectrum (slightly obscured) will show your TX waveform. Click the * and O buttons for different formats.
- You have 10dB boost, it maybe necessary to add a bit more, just depends on the microphone.
- Select the microphone - you're using the Default atm.
- When you click Tune remember you must increase the Drive.
- Make sure you've set the master gains.
